Cooling Sys, etc 08
by
, 20-04-2021 at 09:07 PM (2609 Views)
I will create separated post to properly say thank you to member Heineken so going to just briefly touch on this here.
Already created the DIY function generator years ago and been happy with the accuracy.
The addition of Heineken's gauge simulator will speed up the process.
This is my gauge. Once again, confirmed the previous calibration was good enough.
No need adjusting even with this latest simulator.
Followings are all for the owner's gauge.
Testing the accuracy of the re-generating exactly the same signal output multiple times under different temperature, etc conditions.
The warning LED module and the light bulbs check.
Speedo calibrated.
Tacho calibrated.
