While it will survive and fairly normal to see the potting melted away on the CRK/CYL sensor, I don't feel comfortable re-using this so going to replace it with a new one. All inlet valve guides ...
Quick oil change in preparation for the fire up. As my standard procedure, fresh Mobil 1 in the oil filter but probably not required. Vacuum leak check of the cooling sys. There was super ...
Serviced the power filter board as well. New caps installed. Although I couldn’t re-create the volume ...
After considering the brake balance, risk of re-using the existing brake disc and 100% on the street driving conditions, decided to go for the EBC Redstuff for the rear pad. I use the ...
Updated 10-06-2014 at 10:23 PM by Kaz-kzukNA1
Quite often, being neglected but I don't like the loose cable sitting behind the rad fan. OEM clips installed and looks much better and safer when you open the bonnet. ...
