Started washing the engine. Front bank looked very clean but still, there was some oil seepage around the valve cover gasket at the intake side and at the usual place such as the cam shaft disc seal. ...
New O2 sensor from NTK installed. Once again, the position of rear bank O2 sensor is not great on DC header without extra cable length so it's going to be tight fit. ...
The valve and intake manifold covers washed, degreased and ready for touching up the paint. Couldn't clean them any further without stripping the original paint so it won't look perfect after applying the paint but still, should provide huge difference in appearance. ...
Started the disassembly process. IAT sensor covered in black oil and debris. Will be cleaned and replace the o-ring. With the blowby gas routing on the black valve covers, normally, the ...
Not looking forward in painting this rear valve cover. It’s going to take some time for the preparation….. Time to look into the rear O2 sensor. I can confirm that it was cross-threaded last ...
