View RSS Feed
All Blog Entries
  1. Eng Refresh, Health Check, etc 06
    by , 14-01-2015 at 03:35 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    Very clean exhaust/CAT area. Should be easy to disconnect the spring loaded bolt/nut.
    Interesting way of preventing CEL at ...
  2. Eng Refresh, Health Check, etc 26
    by , 20-12-2014 at 01:31 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
  3. Eng Refresh, Health Check, etc 08
    by , 27-11-2014 at 01:14 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    As reported earlier, there was no point trying to save these heavily corroded spring loaded exh bolts and nuts.
    Ideally, I wanted to break them at different position but the corrosion was so deep that they all snapped off in the middle. Will cut them off later.
  4. Eng Refresh, Health Check, etc 03
    by , 19-11-2014 at 04:36 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    CL master cyl is leaking and the CL hose looked to be seeping the fluid as well.
    To be replaced while the engine is out.
    I was told that the CL slave cyl was replaced in the past so I'll re-use it.
  5. Eng Refresh 06
    by , 14-04-2014 at 12:24 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    The TB drive pulley looked to be rusty as well.
    I have ordered new one just in case.
    Having really big time trying to remove the bolts at the heat shield.
    Always the ones at the rear bank will cause
Page 2 of 2 FirstFirst 12
