View RSS Feed
All Blog Entries
  1. Brake OH, Cooling Sys, etc 29
    by , 22-10-2016 at 12:41 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
  2. Annual Service, Health Check, Brake OH 16
    by , 12-09-2014 at 11:00 AM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    Based on the green/white powder like debris, I'm now 100% convinced that the coolant was leaking from this fitting.
    The photo was taken after I cleaned it but there were markings on the side of the blower motor fan case as well as on the battery top surface.
    Not sure how it can happen as the coolant hose was not replaced in the past so possibly ...
  3. Cooling Sys 02
    by , 20-11-2013 at 10:16 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    New thermostat installed.
    This NSX is AT model so extra hoses at the AT cooler.
    Updated 21-11-2013 at 01:41 PM by Kaz-kzukNA1
    Categories
    Cooling
  4. Preparation
    by , 27-04-2011 at 10:31 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    So, started removing lots of parts to prepare for the compression check before start of the service.
    I’m also going to replace all cooling system hoses and cleaning the A/C evaporator so doing several things in parallel.
    The battery is also going to be replaced with a new one and having the blower motor fan out of the way will make the replacement of the coolant hoses much easier so started working under the bonnet.
    Updated 27-04-2011 at 10:43 PM by Kaz-kzukNA1
    Categories
    Heater, A/C
Page 2 of 2 FirstFirst 12
