Rebuilding the missing joints and strengthening the GND pad. ...
Time to work on the CCU board that was sent through the post recently. It was from the early model NSX. The owner could no longer see anything on the CCU display so he took the CCU out from the car. I sent an email with the information on which capacitors to be checked as there were several capacitors ...
Although the owner didn’t feel any issues with his A/C system, he wanted to take preventative measure and requested the A/C CCU board service. Very good idea and every owners should be doing it. The owner’s CCU board is on the right side and being as the later spec NSX model, the CCU board ...
While working on the engine, worked on the CCU board for another owner. ...
Carried out the test scenarios using the self diagnosis feature as well as the function & operation check mode plus my own test process by installing the board on my NSX. Testing in Mode 03 at the moment..... ...
