The right side tail light alignment was not great against the bumper and the centre & left tail light assy. ...
The noisy cabin temperature sensor. It was full of dust as reported earlier. Disassembled, adjusted and now its clean. ...
Updated 30-11-2013 at 01:05 PM by Kaz-kzukNA1
Already in the process of removing the brake caliper and coolant hoses so doing bit of catch up updating the blog. For some reason, someone trimmed part of the door handle at both R & L sides. ...
Temporarily installed my re-soldered one for a test and confirmed the FCU failure. The faint noise you can hear in the background after replacing the FCU is the aspirator fan at the cabin temperature sensor. As seen on many NSX, it was full of dust making this noise. ...
Updated 11-11-2013 at 02:33 PM by Kaz-kzukNA1
So, took the car to the alignment place. I always use JPS Motorsport because I know their platform is re-calibrated every 6 12 months. Asked the tyre pressure to be left as it was and checked the SAI figure. The existing setup was completely wrong. The only good figure was actually the ...
