View RSS Feed
All Blog Entries
  1. Brake OH, Health Check, etc 11
    by , 18-03-2016 at 01:26 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    With the fluid inside the ABS reservoir exceeding the max level and based on the previous service, I knew this NSX had ABS issue but this time, none of the solenoids were stuck closed and just continuously leaking at multiple solenoids.
  2. Defrost panel, Bilstein damper, iPod adaptor 11
    by , 29-06-2014 at 11:09 AM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    Time to flush the ABS.
    The owner reported that the area around the ABS reservoir was wet and covered in brake fluid so already knew that there were lots of air inside the accumulator.
    He kept exercising the ABS regularly and the ...
  3. Final Touch 02
    by , 21-05-2014 at 01:03 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    Started the flushing service on the classic ABS and as soon as I opened the
    bleeder plug, I knew it’s going to take long time.
    Nothing came out from the accumulator......
    Not a single drip......
    So the accumulator was completely empty.
    Manually activated the ABS pump and immediately, I found the cause of the
  4. Abs
    by , 26-09-2013 at 10:16 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    The view inside the ABS T-wrench.
    It took ages to recover all of the existing brake fluid from the
    accumulator because there was so much air in there.
    Probably it was never flushed in the past and hence I had to open, close the
    bleeder and wait for a while before I could re-open it.
    Updated 27-09-2013 at 12:21 PM by Kaz-kzukNA1
    Categories
    ABS Original
  5. Final Touch
    by , 20-05-2013 at 10:37 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    After bleeding the brake,
    went out for the test driving session.
    This is the first time I used SoS LMA so paid
    extra attention at lower rpm range although
    the test pipe and back box were so loud that
    it eliminated almost all of the sound above 1,500rpm.
    SoS LMA sounded bit different at idle rpm but probably
    that’s just my ear as I knew it’s not exactly the same one
    as the latest OEM one.
    Happy with the
Page 3 of 5 FirstFirst 12345 LastLast
