View RSS Feed
All Blog Entries
  1. Health Check, Brake OH, Koyo Rad, etc 18
    by , 14-11-2015 at 10:39 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    One of the reason why extra time was required on this occasion.
    On arrival, the ABS fluid level was well below the MIN line so I knew there was some issues but turned out, three out of four ABS solenoids had issues.
    Two
    Updated 19-11-2015 at 04:55 PM by Kaz-kzukNA1
    Categories
    ABS Original
  2. Health Check, Annual Service 03
    by , 19-10-2015 at 09:39 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    Pressure bleeding the brake fluid.
    As the owner must replace the rear brake pad, decided to set the fluid level like this on purposely as someone must wind back the rear piston in order to install the new pads and I don’t want to see
  3. Health Check, Annual Service 02
    by , 19-10-2015 at 09:38 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    The fluid level at the ABS reservoir was at the max line so it’s very unlikely but noticed the trace of brake fluid under the caution label.
    May be someone spilled the fluid in the past???
    I’ll be flushing the ABS any way so not a problem.
    By the way, as mentioned in the meeting, please exercise your ABS every time when you take your NSX
  4. Annual Service, Coolant, etc 04
    by , 17-09-2015 at 09:40 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    Noticed that the rubber protector at the right side boot lid hinge was missing.
    Normally, it is trapped inside the drain hole in front of the hinge but on this NSX, it was already gone.
    Had the new one in stock so just installed
    Updated 21-09-2015 at 10:58 AM by Kaz-kzukNA1 (Back dated to 17th to match the Service Log file.)
    Categories
    Health Check Service , ABS Original , Body
  5. ABS Check
    by , 28-07-2014 at 10:39 AM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    As reported earlier, I received many parts from Japan when I placed the order before the parts price went up from 01/Jul onwards.
    One of the parts was the latest ABS modulator and finally I managed to find some time testing it in preparation for the installation in the future.
    As I already upgraded my ABS to the latest ...
Page 3 of 10 FirstFirst 12345 ... LastLast
