This is how the liquid gasket should be applied if the cam shaft was removed and ...
Bit uneven weat at Rear #4 cam holder. ...
From time to time, I have seen casting issue on some of the cam holders. Not a big issue but ideally, I would prefer perfect finish. Not cleaned yet but already, you can see two holes on the cam journal section. ...
It has the 003 later spec LMA so no need to replace them. Still, checked the movement and feeling of the mid rocker arms and LMA. Also, as my standard procedure, confirmed that none of the primary/secondary rocker arms were moving while pressing down and releasing the mid rocker arms. ...
