Before backing off the valve clearance adjuster, I always check the current clearance. On this engine, I was quite surprised to see imbalance of compression data between the cyl on such low mileage and late model NSX so decided to measure the existing clearance even more carefully. #1 IN: 0.19mm, 0.19mm just at the limit #1 EXH: 0.21mm, 0.21mm just at the limit #2 IN: 0.16mm, below 0.15mm too tight ...
Updated 23-02-2014 at 02:38 PM by Kaz-kzukNA1
The VTEC spool valve installed with 2 new gaskets and 6 new bolts at each bank. Later spec smaller diameter solenoid model so P08 version used. ...
Updated 15-01-2014 at 12:16 PM by Kaz-kzukNA1
Long hours marathon session of valve clearance adjustment started. The clearance and the torque checked twice for each cyl and as my standard procedure, they were checked one more time to bring all 24 adjustments ...
Updated 27-10-2013 at 12:27 PM by Kaz-kzukNA1
In the process of clearance adjustment. 24 adjustments were checked twice for the clearance and the torque. ...
What a humid day it was. Completely exhausted after going through the long hours valve clearance adjustment. I have no problem carrying out the TB/WP service without taking the engine out of the chassis but for cleaning the engine and replacing the LMA, I’ll definitely take the engine out if I have to do this again. ...
