ABS Upgrade, Door Window Refresh, etc 12
, 19-06-2015 at 01:31 PM (2898 Views)
Have been tackling the door window alignment for many days recently with one nearly dead finger as a result.
It looks like someone already mistreated some of the parts that I planned reusing and at the end, I had to make custom adjustments that were not on the workshop manual.
As in my previous blog, I should have replaced all four front/rear sashes and not just one of them.
Some of them were internally damaged but couldn’t be seen from outside and looked like excessive force was applied and changed their original shape.
This was the reason why I had to use the custom method for aligning the window because all of the adjusters were maxed out at the right side window.
For any door window refresh, these are the minimum parts to be replaced plus the rear sash and these are just for one side (L side window for the above photo).
Addition to these, there are several parts and spacers to be prepared as you will need to decide where and how many to apply these depending on each NSX.
Again, I have full respect to the Honda people who assembled and adjusted these window glass at the factory because each car has different alignment.
