Cooling Sys, etc 04
, 20-04-2021 at 09:03 PM (1405 Views)
If replacing the wiper blade, please pay extra attention to any aftermarket parts that may change the blade height especially at the passenger side.
You could end up with scratch markings at the back of the bonnet/hood.
This one was just about fine and the scratch was already done before replacing it.
Photo speaks for itself.....
Looks like the A/C compressor was already replaced in the past as the pulley diameter and the connector were different from OEM spec but it's already leaking the oil......
Best dealing with this when Eng/Gbox out of the bay as most likely, you'll need flushing the system and replace a/c compressor, exp. valve, o-ring, drier, etc.
