PS I highly recommed a new fuel filter and a fuel pressure gauge, no fuel = BIG BANG!
I don't really understand what you mean?
The Fuel Pressure Regulators have been red for a long time. *The color does not have anything to do with the internal parts of any regulator. *They're all red.
So there is nothing "hi-boost" about the kit you have.
Dixon
Thanks Ary.
Do you have a picture of your dash with all the extra gauges as I am not sure where to put then without looking to 'Chav'.
What other gauges do you recommend? I was initially thinking an audio or light warning as I am not sure I'll be looking at the gauges whilst I am pushing it.
I can set you up a Defi Fuel pressure gauge and also oil temp and pressure gauge, but you don't really need those if you are only using the car on the road.
All Defi gague comes with warning light and a very annoying 'Beep' at warning so you won't need to look into it.
Or you can have a similar gauge setup like we have done on Mo's car, you can check it out on his when I see you this weekend.
Dixon
When was the last time his fuel filter was changed? Since the CTSC takes the feed from there. It makes A LOT of sense to get a new fuel filter in place. I hope you changed the washers ( new ones with a fuel filter ) to avoid leakeage.
C'mon guys is only like £15.00 for a bloody filter and not really any extra labour.
We will ask the owner when was he last changed the filter, you only need to change them every 60000 miles anyway and his car just passed that.
