Results 11 to 20 of 24
Thread: Using Jump Start terminals for trickle charger?
  1. Default
    Thanks for the info Kaz - much appreciated. Will look into adding an inline fuse to give myself a bit more protection.
    Cheers!
    i have this on mine.... fuse already in line
    https://www.amazon.co.uk/CTEK-40-133...xgb449-21&th=1
    Thanks - makes things easier
    Fitted the ctek this morning. Changed the 3 pin plug into a waterproof connector that then connects to an outdoor rated lead into my garage (NSX currently parked outdoors)
    All seems to be working ok - thanks for the info guys.
  5. #15
    Without wishing to cause any unnecessary worries, the use of the CTEK MX5 seems to have killed my NSX's battery. It was working fine for several weeks - the string of LEDs showing progress illuminated and then changed as normal = all healthy. And then one day the string of LEDs was not lit.
    Now, when disconnecting and reconnecting, the CTEK doesn't seem to think there's a battery attached.
    I will investigate more this week.
  6. #16
    I have a CTEK MX5 - it has been used without any problems since 2018.
    Mike
  7. #17
    Quote Originally Posted by sorepaws View Post
    Yes, this one has worked fine for several months. I checked it every morning.
    Am hoping it was just a bad battery.
  8. #18
    Quote Originally Posted by goldtop View Post
    did the ctek get switched off at the power source?
    i found that if its not powered up, but still connected to the battery it WILL discharge the battery completely. so if you want to switch it off overnight, for example, i HAVE to unclip it from the battery too
    and i have found if a battery is very flat i have to give it a kick with a conventional battery charger, to get enough voltage for the ctek to recognise a battery is connected
  9. #19
    Not switched off, as far as I know. Unless there was a power cut at the workshop?
    (Bizarre that the CTEK wouldn't have a simple diode fitted to stop discharge of the battery!)
  10. Default
    Hopefully you'll figure out what happened. You can get a battery health tester to see what condition the battery is in. Like you say it probably was that
