Introduction The Gauge Cluster suffers from ageing capacitors as many ECUs in the NSX do. Leaking capacitors at the gauge cluster is a serious issue. Acid near the warning indicator circuit causes shorts and even potentially lead to a fire. Same as with the other capacitor issues, a replacement should be considered before the unit fails. Diagnostic First signs are a non-accurate speed indication or a permanently lit brake light warning even though bulbs and wiring are ...
Updated 17-12-2022 at 02:41 PM by Heineken
Another strange year has gone by…. Hope everyone is doing fine and keeping safe. Missed the Silverstone Classic 2 years in a row but got close to GT ...
Updated 22-12-2021 at 10:12 PM by Kaz-kzukNA1
When I first received this CCU board, I was worried about the damages to the big IC1 based on so many components being bent, etc. However, the self diag worked fine and even the logic of function & operation check were carried out without any issues that IC1 was very unlikely to be damaged. Just the fan speed control. ...
