Vacuum leak check of the cooling system. While keeping the system under vacuum, started preparation for cranking the engine. New battery installed. ...
Just when I thought I can move on to the next service item, I noticed that the cabin temperature sensor (aspirator fan) was making annoying noise. Although it was not included in the service menu, I didn’t want to leave it like this when the owner was not happy with all sorts of noise after the security system ...
There are several sensors connected to the A/C CCU board and their inputs are used to determine the fan speed, A/C On/Off, VENT mode, etc based on the targeted temperature setup. One of the sensor is for the cabin air temperature and it is located behind the small slits on the centre console next to the ashtray lid in ...
Started to work on another NSX from this week. The owner bought this NSX recently and although there were lots of documents and stamps related to the previous services, the owner wanted to have the car checked through my Health Check service despite the car was at super low mileage and fairly late model. By this approach, we can start working on the common service items while waiting for the parts delivery if I find anything needs to be done ...
Suspension bush related bolts and nuts were torqued under 1G. Low speed test driving on the lift to confirm that no leakage of MTF or no noise from the rear end. As parking brake cable was seized at both callipers, it had to be adjusted from scratch. Will finalise the adjustment after the test driving session. ...
