Results 1 to 3 of 3
Thread: Rear wheel hubs / bearings
    Default Rear wheel hubs / bearings
    For a 1995 UKDM Manual Coupe
    I can see 2 part numbers for the rear wheel hub/ bearing assembly
    42300-SL0-008 and
    42300-SL0-305,
    both appear to be advertised, should I pick one over the other.
    Differences/ thoughts?
    Thanks,
    Duncan
    -008 is the original # but now superseded to -305.
    Generally speaking, Honda changed some of the parts # to -305 that stands for an 'assy' when the parts is a 'set', 'kit', 'assembly', etc.
    So, -305 please.
    Thank you Kaz for your explanation and quick reply, -305 it will be.
